Aaen singal pipe on phazer 2
PINHEAD
Haliburton
I have a aaen pipe for my phazer 2 and what I have found is to run 150 mains in my sled and she wont blow.Now I might not be correct till I jet it and do plug checks.Anyway all I want to know is what style of mains are in the carbs?
Hex heads?
Sloted round type?
The sled runs perfect right now as it got the top end rebuilt last year from a 488 to a 502 dont know how many .00 over that is.I just dont want to take a running sled apart then have to wait for the jets to arrive,and I hate takin those darn carbs off!!
:letitsnow
that sounds a little rich but rich is better you sled is bored to .060'' so you do not want to blow it up bad if not the cylinders will be junk depending on the aaen pipe you have quiet can torquer or race will depend on the jetting make sure you jump to 110 pilots as the tock 95 pilots will cause low to mid range lean plus you will have to adjust you clutching to take advantage of the new found hp
Thanks I think I'm just going to leave it as it runs mint and don't want to do another motor job so pipe is for sale
