1998 mountain srx 700 idles low
Gerryjackman
Alberta
Hey guys still diggin into this sled I bought 1998 mountain srx seems to run great 99 percent of the time but at idle it will drop to roughly 1300 rpm but of you bump the throttle takes it right back to normal about 1800 any help is greatly appreciated
Your not giving us mutch to go on as to what you have checked.
It could be a spark plug on the way out or a cap..replace all if still origanal
carb cleaning... jets are very small on this sled and must be done properly
Drive belt..the wrong belt will hold back idle but should be easy to check
Compression down on one jug will do the same.And have you set the idle and than readjusted the throttle freeplay.Make shure cables are in there holders and tors is working properly.
