t-rav
ok guys i ran my sled lots this year ran real nice and strong but now im having major issues what is happening is the machine will run fine then all the sudden all the lights go off it idles down and the heat light flashes but not overheating and iff i press the gas its as iff its only running on 1 cylinder but then all the sudden runs ok again does it on and off thinking possibly a short somewhere
SWEDE
Probably a rub through where the wiring harness goes under the engine. This is a quite common problem on a lot of these sleds.
t-rav
kinda what im leaning towards thanx ill have to pull the motor i guess lol fun
also check wires under the handlebar padding.Mice got me there 1 season and bare wire was grounding to bar..also run the sled ina building with all the lights off and look for arching.When I re routed my harness over the pull start,the damn exhaust melted wires..started to loose power,gauges where shuting off and then back on.I found the arching in the dark and fixed them and re routed wires again...
Devilin AblueDress!
t-rav said:kinda what im leaning towards thanx ill have to pull the motor i guess lol fun
You can tie a string on harness, pull out backside of motor, inspect/fix. Use string to pull harness back threw. Not a barrel of laughs but easier than pulling motor.
there is a tab under the motor where I couldn't pull past..so just check what I could pull.Best is when the engine is out and you can install loom over the cable
Devilin AblueDress!
bluemonster1 said:there is a tab under the motor where I couldn't pull past..so just check what I could pull.Best is when the engine is out and you can install loom over the cable
Now that you mention that tab/tang thing I remember fighting it myself. Actually went to a carcass and veried what I couldnt see. Kind of had to nearly stand on my head and contort my arm up under front of motor to bend that up and release harness.
I can almost see the devil in a blue dress standing on his head..hope you wore panties....lmao....couldn't resist...Devilin AblueDress! said:Now that you mention that tab/tang thing I remember fighting it myself. Actually went to a carcass and veried what I couldnt see. Kind of had to nearly stand on my head and contort my arm up under front of motor to bend that up and release harness.
super1c
Super Moderator
bluemonster1 said:I can almost see the devil in a blue dress standing on his head..hope you wore panties....lmao....couldn't resist...
LOL! Now that was a good laugh, ive met him and that would not be a pretty site! JK!
Devilin AblueDress!
super1c said:LOL! Now that was a good laugh, ive met him and that would not be a pretty site! JK!
Come on guys.....wheres the LOVE? I am sure it wasnt a pretty sight, Pretty sure had any one seen it they would have gotten a good laugh, followed by What are you doing? Had the pipes off but manifolds off. Dont remeber the winning combo of "elbow jammed into bumper brace,forearm above tie rods with the bars in this exact position and make sure your wrist is smashed against the side of waterpump" But in the end I got the little thing to release the harness!
Devilin AblueDress!
bluemonster1 said:![]()
come on now!!!
......of me in a blue dress?......sorry...couldnt resist!
staggs65
All right guys, it is quite funny but lets get back on track. lol
humor is good for the soul Jeff and them 8bu's as well...just joking on the 8bu's..
