Warning lights??
95rxl650
Georgian Bay, Ontario
On my 98 srx 700, should I see any lights on start up?
Nothing flashes at all, but after some searching I couldnt determine if all years had it built in.
I would think they all might come on and then go away like a vehicle, but could be wrong. never paid attention to mine....but need to start. lol
staggs65 said:
on yours Cooper you should get 3 blinks. that basically means all systems go.
I'm not sure if 98 is the same. hopefully someone else chimes in for you
Kewl, I'll have to write this down for when I get it back together.
Thanks Staggs
If your not seeing any flashes at all and the sled works fine I'd say you might possibly have a bad bulb in the tach for the red temp light indicator.It should flash 3 times at start up if everythhing is ok.
