'02viperman
Reassembling crankcases... not quite sure how to place the circlips in bearing grooves with regard to the crankcase halves. Should they be positioned in the lower case half? That's how the microfiche shows them. Though, when I disassembled it, I feel like I remember them positioned so as to split the case halves, half of it in top case, half in bottom. Please advise. Thanks!
when I did mine,I went basically half and half. Remembered reading that in the manual.I was wandering about that to at the time...
I printed it from the manual and scanned it..best I can get it.Looks like retainer(top pic) is 2/3 on top case and 1/3 bottom case
journeyman
[QUOTE='02viperman]Reassembling crankcases... not quite sure how to place the circlips in bearing grooves with regard to the crankcase halves. Should they be positioned in the lower case half? That's how the microfiche shows them. Though, when I disassembled it, I feel like I remember them positioned so as to split the case halves, half of it in top case, half in bottom. Please advise. Thanks![/QUOTE]
Looks like you are new here. This post should go into the category that includes your machine which I assume is a Viper. This head to head section is for racing talk between different machines.
thanks....
thanks....
staggs65
journeyman said:Looks like you are new here. This post should go into the category that includes your machine which I assume is a Viper. This head to head section is for racing talk between different machines.
thanks....
lol. good thing you caught it cause I didnt. moved
'02viperman
Wow!
Wow! You a racer? How many trophy you have? Sorry for being in wrong forum. I be more careful next time.journeyman said:Looks like you are new here. This post should go into the category that includes your machine which I assume is a Viper. This head to head section is for racing talk between different machines.
thanks....
'02viperman
Much appreciated!!
Thanks guy for the info.bluemonster1 said:when I did mine,I went basically half and half. Remembered reading that in the manual.I was wandering about that to at the time...
