sledneckdon
Charged battery and checked voltage 11.90 then started sled checked voltage again 12.39 so the battery is charging when sled is running does this mean the stator is good?????
livewire_101proof
On my er, even though its charging, the guages will do that if the battery is junk.
Ditto.....What he ^^ said been there done that...
x3 same thing happened to me! Replaced Battery and all good!
sledneckdon
found it thanks
thanks easy way to check if it is the battery is to put on a portable jump starter power pack and if it goes away it is a junk battery
