ski doo pilots on a mountain max
ebayfreak
newfoundland, Canada
just wondering what brackets are needed to put these skis on a mm. Where can i get a set of brackets if i need them. I want to be able to convert them back to yamaha skis if need be.thanks!
You do not need brackets they are built into the pilots. Use your stock rubber dampers. Pop one bushing out of the pilots and install the bushing backwards. It has been a while since I did my SRX so I may have forgotten something.
