helix
t-rav
hanmer,ontario
i have a bunch of different angled helixed wich would be best to radar run with i have 3 maga power 60/40 and 58/42 2 micro belmont 54/42 and 50/45 and a advant edge not sure ancle but seems to run real good and the weights are loaded 8bu-10s with w-w-w primary and green sec which helix is best for radar runs i currently have a hauck 51/43 on it now
in this area the runs are 2000ft is Trav is talking about NBSSR.
Are there any other mods to the sled. What is your shift RPM right now
Runs up here are 1320. Distance was changed last season. As far as the proper helix for radar runs is concerned you will have to experiment. Testing on the day is the only way to know for sure. We make multiple helix changes in one day at the runs. Bring them all and test test test!
If you are running over 1000ft' try that 51/43 with a silver secondary spring and a very light wrap around 40-50 deg. you should pickup some MPH, and not lose alot of acceleration off the line. You could try that 54/42 silver with more wrap too.
