2003 sxr 600 tors acting up
EvanD
mas
Working on a friends 03 sxr for him.sleds runs awesome other then what seems to be the tors acting up.when on the throttle hard for a short burst then let of and go to get on out again it cuts out. Like the tors was triggered? i had the same problem with a Yamaha blaster and just eliminated the tors and all was well. How do i go about fixing the tors or eliminating it?
Evan
Most common trigger is throttle cable to tight, need 1-2 mm off free play. Loosen it up and check back. Many threads about bypassing as well as a write up in the tech section about tors
