adjusting rsi cable
belcher
canad
At idle where should the oil pump lever be? or at what throttle position should it start moving? I installed cable at first so the oil lever stopped at the same time as the throttle sopped but now can't adjust better than 20.1 i guess i'm back to taking carbs off and motor mounts to readjust. another thing would to much oil cause the engine not to rev? I just got sled and imediately put the boss seat on and riser with the rsi cables. The machine hits about 8000 and stays close to there.
