98 srx700
yamyrider
Northern Ontario
very boggy. checked compression all cylinders are 120. cleaned clutches.
Sled wont go faster then 35 to 40mph...can power valves cause that slow of a sled?
sounds more like the carbs are dirty, have you cleaned them? i would check them first. when it starts to bog you can pull the choke half way to see if the rpms comes up,
I opened the carbs again even tough I had cleaned them and I guess I forgot to tighen the main jet in the PTO side and I see he main jet siting in the bowl. ant believe I did that. Checked all carbs again and works fine. Now I know why I fould a plug...way too much fuel in the main.
