Diceman
I have a 77 Sno Jet SST with a Mikuni carb...sled was bogging out at higher speeds, almost like getting to much gas...took carb off, cleaned it and although there is way more bottom end jump since the cleaning, top end stills boggs at times but will then kick in....I was then told that my bottom of my carb has a Dail a Jet add on to it...there is a white plastic screw at the bottom of the carb plus a small hose running up to the body of the carb...was told the original carb has set jets so that is why we are thinking its an add on.... ....anyone know how these work or what a normal setting is on them?..Thanks
WopOnTour
pics? is this a "dial-a-jet" (hose from float bowl goes to a delivery nozzle in the inlet of the carb) like shown here:http://www.thunderproducts.com/dial_a_jet.htm
OR
is this standard "adjustable main jet" which usually gives you ~8 main jet sizes for easier temp and altitude tuning of TOP END fueling.
If you can measure the inside and outside diameter of the carb outlet (engine side) we can maybe figure out what size VM carb you have
WOT
OR
WOT
Diceman
will try to post pic...keeps saying pic is too big....I think it is a vm 36 carb....it does have a hose coming from the float bowl....DicemanWopOnTour said:pics? is this a "dial-a-jet" (hose from float bowl goes to a delivery nozzle in the inlet of the carb) like shown here:http://www.thunderproducts.com/dial_a_jet.htm
OR
WOT
staggs65
load the pics on photobucket.com then copy and paste the IMG code from photobucket into your post here.
Diceman
http://www.vintagesnowmobile.com/cgi-bin/yabb2/YaBB.pl?board=snojet
a link to the pic of the carb Thanks
Topic Called...... Setting Carb (Gas Mixture) , 77 SST Yamaha Engine
