well going on a trip this weekend and well after i finished cleaning the carbs and raising the needle to 4th groove, i started the sled and took it for a drive..after a few minutes..temp light flashes 8 times and keeps repeating..mostly at idle but sometimes while driving..need help..whats 8 flashes mean! i seen someone say bad thermosensor and some say bad fuel sender..what is it..thanks
all I can see in the fault table is 7 flashe's, and that is servo motor issue..there is nothing for 8 flashes.
Ya that's what I found so I went looking on the internet and found thermo sensor is the cause(where it plugs into the head) so I went to unplug it and found the wire pulled out of the plug...just thought I would post in case someone else is faced with this code
viper700t said:Ya that's what I found so I went looking on the internet and found thermo sensor is the cause(where it plugs into the head) so I went to unplug it and found the wire pulled out of the plug...just thought I would post in case someone else is faced with this code
Search Yoopermike. He just went through the same thing and repaired the connection.
