97' 700 SX carbide install
dblshock
WI.
Can't believe Bergstrom sent me triple points w/ski savers but with no install diagram..the question I'd have is they came with quarter sized washers on all four studs and I have no clue as to where the washers should be placed..above the Bergstrom ski saver? above the ski skin? or above the metal ski just below the nut?
have the oem ski
Below the nut on top of the ski. Every one I have ever put on was that way. Not sure if there is anything else to do w ski savers.
Thinking it should go just under the metal ski, topside of the skin?..When I called Bergstrom the lady was not very certain, she hollered back into the shop..came back and said with uncertainty 'under the ski'..whatever that meant.
Ski saver is mounted between the carbide and the bottom ide of the ski. In your case it would be between the plastic ski skin and carbide. The washers are for the nuts that hold the carbide so they would be located between the nut and top of ski.
The pic in above post is also very clear in how to install.
