o'l sparky
Recently bought the sled, ran great,had it out for about 25 miles and came home turned it off,went out 30 minutes later to move it into garage and it wouldnt start.
Had ignition coil tested,its fine on the bench had one spark plug cap test"open".
When it wouldnt start initially and I pulled to start it, the headlight would come on, now when I pull it does not.
Tried unplugging the key switch,no spark, the kill switch is unhooked and looped into itself, bought it that way.
Leaning towards the stator, as why do my lights not come on when I pull now , when they did a few days ago?
So does any one know how do I test the stator, what it should read when tested and also what setting my multimeter should be on to test it?
Or have any other suggestions as what to do or check?
