02 viper er..electrical problem..
roscoman
mich
just put new rings on a 02 viper er i just bought..for some stange reason the gauge is popping on /off..sometimes it will work for 20 seconds before doin it and then it constantly on/off. the only thing i did was take out the battery.. im assuming they can run without battery but does anyone else have any opinions...thanx 4 ur time
sounds like mine without es,possible rub through under the motor,headlights dim also when gauge goes intermittent?id try easy first,put the battery back in and make sure its good,then try it,if thats not it then look for rubthrough-if none of the above then possible stator.~smoke
