Hi !
I thinking of putting SLP Powder Pro skis on wifes Exciter-II
The question is what needs to be done to make it fit the TSS struts ??
Which SLP ski saddle bracket is best to build upon to fit the TSS struts ??
http://www.startinglineproducts.com/
Vmax540
Not sure which SLP ski saddle bracket will fit the TSS struts. You need a saddle that is deep enough for the TSS mount and even if the saddle is too wide you can shim the outside of the ski mount and have a wider ski stance as a bonus !
Throttle Junkie35
Hmmm, not sure about the slp brackets, however usi has brackets /skiis for the T.S.S. Maybe you could fab something up to mate the slp skis to usi brackets?? As 540 said i suppose you could always shim etc. The next problem you would have to solve will be the bumpers where the usi skis are a direct bolt on.
I have made my own bumpers out of this rubber/ urethane stuff that a friend of mine gets from work. I guess he uses it to set sheets of glass on. Im sure you could find some at any glass shop. Its almost the perfect size and all you have to do is cut the profile. I hope this helps.
Yamaha Nutz
Std trailing arm yamaha mounts should work we have sly dogs on one of our phazers
