NY AttakGT
Does it matter what size drill bit I use to synch the carbs for a triple? Or just to make sure that they are all the same? Thanx <)
I would use the size that just fits through and bump it up 1/64 and then set them....
bluehammer
I use 2.5mm.
MountainMax
I don't matter, it's just so they are all the same height in relation to each other, as you adjust the idle they will all change anyhow.
