Can anybody tell me if a 1.25 ripsawtrack will work on a 97 xtc 500 without much in the way of mods.
Chris
Chris
super1c
Super Moderator
You will be fine if your not running studs. You might have to clip the lugs at the windows so they dont rub on the heat exchanger guards of your using those.
richierich
It'll fit right in and a great upgrade.Your sled didnt come with protectors but if someone studded the sled it might have them so just double check.
jasburrito
I have that track on mine. works great. I installed tunnel and heat exchanger protection with short studs. I cut track to clear protectors.
