Holtzman ATACC Install questions
Automed
Edmonton, Alberta
I bought this sled with the Holtzman ATTAC installed.
What's up with the clear hose wrapped around the spark plug wires???
Can this hose be shortened? I read the installation instructions from Holtzman's website and it does say not to cut the blue hose but what about the clear hose from the carb???
Clear Hose
You can shorten the hose but it will make the ATTAC more aggressive in terms of response. I believe the hose is supposed to be 24" and it's in the instructions somewhere (I think on the picture). You can give Barry Holtzman a call for the specifics but the length is important. I just coiled mine up once and tucked it down on top of the carbs with a small zip tie to keep it from flopping. I know it doesn't look as clean as a short length of hose but don't just chop it shorter for looks or you will be leaner than you were before.
