dealer told me that if i want more out of your 780 then notch the pickup coil slide it back till the screw hit the housing and thats 3* have u guys heard about this one what to do hmmmmmmmmmm
383stroker
I have done it to a 700 before. You have to jet it up to keep the pistons cool because to the advanted timing. You will gain out of the hole and mid range but you will loose some top end. I liked it on my trail sled. But are trails are pretty tight here.
383stroker said:I have done it to a 700 before. You have to jet it up to keep the pistons cool because to the advanted timing. You will gain out of the hole and mid range but you will loose some top end. I liked it on my trail sled. But are trails are pretty tight here.
do you have a pic on where you made your adjustment
Thanks Andy
better idea just to buy a timing key offset way easier
where can you pick one of these up Timing Key
