SRX 700 - Only middle cylinder running
M_H_SRX
Sweden
Hi! First start for the season today and the engine just runs on the middle cylinder. I have pulled the plugs and they all seems to work. I have also interchanged them with the same result. With engine starter spray the engine fires on all cylinders, so I guess its not a ignition problem.
In the end of last season I emptied the fuel tank. Could this make some membrane in the carbs (is there any?) dry and get stuck?
/Martin
Cleaned the carbs an started it up in the garage for a few seconds and it was running on all three cylinders. It is 1 am here now so I have to go to bed (tired after some hours in the garage). Looking forward to tomorrow.
Thank you all for the answers ;)!
