Stock Viper Fuel Screw Position
sxviperfan
southwest lower michigan
Im, Sure This Has Been Posted Alot But I Will Ask Anyway.on My Stock 02 Viper,how Many Turns Out On The Fuel Screws Are You Guys Finding That Works The Best? I Am A Little Less Than 2 Turns Out From Thr Seated Position And I Have To Blip The Throttle To Come Down On The Idle.
lower your idle speed to 1400 -1500 rpms. If it is to high like around 2000 it will always high idle when you come to a stop. The nature of the flat slide cab. It worked on mine and I'm 1 3/4 out on the fuel screws.
Wolfman
The motor does shake a little when you look at it, but you do not feel it when you are on the sled.
Wolfman
