8ca mountain setup
00sxrjoe
Maine
Any one used 8ca in there mm or long tracked sx. I looking for a base line to start tuneing from.
honestly, that would not be a good mountain weight its too aggressive on the upshift, will likely lead to trenching, something more like a 8dg weight or 8dn10 would be alot better.
I have a set of 8cr so I'll just go with them then. Prob have to load them up to work with a 45/41?
how much weight you add to a clutch weight is dictated by the primary spring used, a stronger spring will require more weight to be added to run a certain rpm, a softer spring will require less weight to be added.
