viperhauck
Does it exist a 24 sprocket/gear to viper/srx? If where can i find it?
			high performance engineering and microbellmont used to have them.
			Vt Srx
I just bought one from high performance engineering a couple weeks ago. The gear has a collar made onto it, it isn't flat like a stock gear. The collar isn't the same thickness as the stock spacer behind your top gear. I removed the stock spacer and ran a thinner spacer on my bottom gear to get the correct offset.
			go to ebay and get a polaris hyvo gear. works good
			doesn't worth the money unless u race on ice
			viperhauck
The reason that I want it is I have a 1000cc engine. 8 thoot noslip. Have 23/40 gearing now with a new 70 link chain. Want to gear it up and use a 37 bottom gear and a 24 upper so I can use the chain
