bigchike350
The treads look good, has happened 3 times now, also the last time it did it the jackshaft had moved to the left causing the sprocket to fall in the bottom of the chain case.. Just wondering why this nut won't stay tight.
I had a top sprocket nut back off on my SRX a few years back. Since then I have always ensured the curved washer is in good shaope and in place and I clean the shaft threads with solvent, wipe dry then use Red loctite on the threads and torque the nut to Yamaha specs. I have never had another issue with the nut coming loose for 1000s of miles.
Works for me..
Works for me..
killerklown
wow, never saw this one before...
Vt Srx
I also had one back off on my SRX and ruin a ride. I do what Bob does except I use blue loctite, the red scares me.
YAMMIEGOD3:16
ME EITHER, BOB RED LOCTITIE ? FEEL BETTER WITH BLUE. 3:16 (yammie tony)
Yes I use Red...I don't want it coming loose again.
I heat the nut with a torch to remove it to melt the red loctite for removal.
TopGunnSrx
I never get that lucky, usually its a chain followed by case.....
mine never has come off..just torque it right.Manual says only use loctite on bottom sprocket bolt.Works for me..The key is the curved washer..
Cam/ Viper adict
My Viper did it twice to me last year.. I got a new washer and used red loctite.. No more problems yet and have put over 1000kms since. I asked around and not many people heard of this happening. Have had my sled for 8-9yrs and never had that problem till last season.. New washer seemed to really help, I think they wear out..
staggs65
I had it happen a few years ago too. Been using blue loctite on it ever since.
