Power valves servo
striker7284bass
rochester, ny
Hello,
I took my power valves and exhaust out to replace some gaskets I had pulled through power valves I had them repaired and have reinstalled exhaust and power valves. I let the engine start, saw the servo motor turn clockwise when idle around 900 I shut engine off. I marked the spots on the pulley and servo back plate. I loosed the adjusting nuts at the servo motor and then loosen the two allen screws on each power valve. The servo motor moved so I tried to move it back but it wont stay in the spot I have marked it with the permanent marker. Can someone help me on what I am doing incorrect or what i should do next this is my first time doing it and I looked at the other threads and couldnt figure this out. Thank you.
Over tight has moved the servo pully and you have to restart to have the pully back to full open were it is marked.
If you are clumsey and always in a hurry LIKE ME this how i go about it.Remove cover and lossen the cable adjuster lock bolts off and the three adusters so you can see some play in the cables or with your finger.Start sled and go for full pull..shut it off..place some vicegrips on the pully with a rag underneath the jaws and wire it so you cannot move the pully by overadjusting.
