PowerValve-700
What do you guys use to shine up your ceramic coated pipes? I tried Turtle Wax chrome polish and Mothers aluminum polish and both just dulled the finish. Thanx.
intoodeep
These are mine with Mothers, whatever you use make sure you take of the residue with alcohol to prevent any sort of coloring due to heat.
The Snakester
HPC sells a cleaner/polish that should work well
PowerValve-700
Thanx guys, I might try the mothers again because I never used anything to remove the residue last time. Test on the bottom of the pipe.
