Bender Transfer Rod Question!!!!!!!!!
I have had the benders and liked them. It seems most prefer the Max rods due to the Benders freezing up. I have never had that problem however. As far as weight transfer goes no, they do not limit weight transfer. They just allow you to adjust the amount of transfer. I have heard something about limiting the suspension travel but have seen no proof or noticed any difference in travel with out them. As a matter of fact I just installed them on my 05 Warrior as they allow more adjustment than the stock adjusters.
Red - I think the issue is: Bender made several different rods. IF you add long travel or a max long travel kit - one version of benders couples to tight. I did some specific measurements and switched late in my ownership. Probably just being a perfectionist, but an 1/8"(for example) is a lot. If I were buying today - go with maxximums
IMO - every sx needs these rods, long travel, and seriuos clutch work and youve got a super sled - the triple pipes just make it super duper
go with benders ts3 system they help alot they dont limit travel on an srx but do limit a little bit of travel on sxr have had them on both sleds a must have take half hour to put in the ts3
