ttr
I got an old 1985 bravo for the kids and it will not pump fuel. I bought anew fuel pump and it still will not pump. Just wondering is it common for crank seals to go out and that is why it wont pump. I also installed new impulse line.
opsled
Check the in tank filter. Could be plugged or colapsed.
opsled
opsled
ttr
opsled said:Check the in tank filter. Could be plugged or colapsed.
opsled[/QUO
I ran a fuel line into a small bottle filled with fuel and icouldnt get it to pump. ITs enough to drive you crazy
toddmod
Can you get another impulse from another snowmobile engine? just to see if it makes the fuel pump work? 4ft of vacuum line & another snowmobile.
is the pulse line from the case good? no cracks or dry rotted?
put a vac guage on the pulse line and pull it over about 5-10 times,what does it read?
