Cooper0809
posting for my brother. hes been grinding the studs off for the past 1 1/2hrs and has only taken off about 10 so far. just wondering if theres a faster easier way to do this.
thanks guys
thanks guys
Devilin AblueDress!
These are the ones he ground off the tip because they were to long? What kind are they? A pic would help. Seems as though he should still be able to just take them out.
Cooper0809
well, im at home and hes at his place so I cant get a pic for ya. sorry. not too sure what kind they are. hes actually removing all the studs because a couple have hit his heat exchanger so hes worried more damage. hes using a grinder, I'm pretty sure they are SS.
usually you put a torx bit into the stud head to hold it and use impact on the nut to remove.But if the hole are plugged,you have to use a pic to clean out all the crap..If nts are rusted and head get stripped,,then grinder is the only slow way..good luck.
bluewho
Yes the SS picks are a real pain to remove ! You have to use a brazing tip on a torch with a nice sharp flame that will warm up the thread lock on the nuts.
justin1620
Heavy duty bolt cutters work.....cut the nut on an angle
95rxl650
I took some of mine out with a 12v impact with a 3/8 socket adapter and a hex socket. Wrench on the nut and have at it.
It's a pain laying on your side to do it, but it worked. As mentioned, you have to clean out the holes to get the hex in.
I gave up and cut the studs down with an angle grinder for this year. New track next year. Mine were aluminum and easy to cut.
