roudyroy1
just had the carbs cleaned, and when i got it back it will start cold with no throttle, but when its warm it takes 4 pulls or i need to apply throttle? it wont even fire if i dont give it throttle, until the 4th pull
			TopGunnSrx
Crack the throttle has been on all the yamaha sleds ive seen. One pull usually with a cracked throttle.....
			motorhead327
There have been reports that new needles and seats will fix this in the T.Y. archives.
			SX600abuser
TopGunnSrx said:Crack the throttle has been on all the yamaha sleds ive seen. One pull usually with a cracked throttle.....
Agreed. Every single triple I have ever ran requires you to crack the throttle when warm.
motorhead327
Mine must be a lemon. Starts 1/2 pull hot no throttle or choke.
							SX600abuser
I personally think they do this because they are jetted fat from the factory.  If you were to dial in the jetting a bit more, I think it may cure this.
			roudyroy1
alright guys, just wanted to make sure she was normal. just put 488 km on in the last 4 days!
			roudyroy1
Well, its the ond of the year now and I want to pull it apart to try and fix this. Could the floats be out of adjustment?
			Mine usually only gives me lip when it's about halfway between warm and bone cold as if I go riding then try to fire it up an hour or two later before it's completely cold. Warm one or two pulls. Cold usually about 3-5 tops. Mid temp could be 20 or more if I don't crack the throttle.
