I need to find out what the stock PV cable lengths are for 2001/2002 SRX. I know 98's are shorter and Viper one's may be longer.For cyl 1 and 2(same size) and cyl #3 (longer).Not the wire cable inside the line,but the actual line itself from the end of the threads(were is screws into servo) to the other end where it stops at the housing. I am using some old ones from years back from a Viper which tend to be a little to long,but can still work.Trying to get used ones from a member and need them measurements because he has various ones,some are from the Vipers.Thanks in advance guys.Got to solve my PV cable issue and try different things with the valves.I filed the slot on the SS inserts so it is not sharp,and still another cable was cutting last week.I am now thinking maybe on the inside of the end where the tip slides into has a sharp edge above it where the slot comes thru.Have to try and smooth the inside of the slot now..my only and last hope to solve the issue.Or like bluewho suggested..maybe drill a little round hole thru the slot center where the cable is running through..
