viper mtn
- Feb 16, 2006
I currently have a Viper with an Ekholm 144 tunnel. Looking to extend the track/tunnel. I recently came across a good price on an Ekholm 151 tunnel off a Moutain Max. Does anyone know if this tunnel could be used on a Viper?
SX600abuser
It should be the same at the front and as long as you are running the same skid out back, you should be good to go.
willinwillys
Should be the same might be interested in your 144 tunnel if your selling?
viper mtn
- Feb 16, 2006
Thanks guys!
Keep ya in mind willy if I pick up a new one.
save yourself a lot of time and labor and just fabricate your own extension. if you have ever done a tunnel swap, you will know what i mean. if not, your avbout to learn what i mean. with the right access, you can extend that tunnel to 151 for around $75, last one i did. only difference betwen the 2 tunnels is the exit for the rear exhanger and the tunnel length.
I was able to extend my Ekholm 144 and make it a tip-up at the same time. Way easier than swapping tunnels
