Primary concern
newtoblue
MN
Hey guys, at WOT my sled jumps to 8600 and stays there, is that a good place to be or would I get a little more power with a little lower rpm. It's a 2000 srx 700. Max speed is around 95, stock weights looks like an orange primary and black secondary spring. It is stock except for bender can and cold air kit. TIA
specs are usually 8500 +/- 100 rpm.That should be fine.If you want to drop it another 100 rpm,could add a .4/.5 g washer to the tip rivet.That would give you about 1.2/1.5 grams total and should drop you approx 100/150 rpm..But I would leave it,it will vary in different conditions and temps anyways..
