Hey guys I have an 02 srx 700 with electric start. Not seeing this as an option listed in parts. Don't have a clue where to get a starter relay. It has 2 30 amp fuses pluged into it and a 4 prong plug with wires from ignition switch and back up alarm wires (also has reverse) and 2 battery cable terminals. I'm pretty sure it's bad but can't make out part number on it. It's located on right side behind footwell vent. Anybody gotta clue? Says something like M55F-441 12volt of M558? 34K
super1c
Super Moderator
SRX's never came with e start so its a add on. What makes you think relay is bad? Take a screw driver and put it across both leads (battery leads). If it fires the starter work your way back to ignition.
