track for 97 vmax 700sx
jrnation88
idaho
just got this sled and the track seems to have no lugs. not use to the sled is that normal, can i replace with a track with bigger lugs any help will be apreciated
factory track is only a 3/4 inch lug. I believe 1 1/4 lug is about the biggest you can go without removing the heat shield then I think you could only do 1 1/2.
