oil light on viper
blevis213
VIP Lifetime Member
new york
my father in law has 02 viper. oil light came on and sled is full with oil. replaced oil sending unit and light still on after starting but 5 minutes of riding goes off. self diagnostic light goes off once to when starting. rub through? any ideas are helpful, thanks
all oil lines good? cable adjusted correctly,connected ?sure its pumping oil?where in ny blevis?
everything looks good. Replaced oil sendind unit in the oil tank. Light still came on. Wire harnesses going through the cowl has a break going to fix or replace. located in fulton county area
i have on occasion bought new things that were bad,just a possibility idk if theres a way to test it!!
~smoke
im in oswego county!!
Found a bad hot red wire under the motor that was bare. The wire must of been the hot wire from the oil unit because their the same color. So far so good
