I have a 1996 VMax 600 2up that appears to be wearing the belt on one side. I only got one chance to ride last year by trailering up north and I noticed fibers flying around. I pulled the primary and secondary and all appears fine, offset and center line is also fine. Also motor mounts are all solid, tried moving the motor and each mount with a pry bar and nothing moves. Maybe the secondary sliding sheave was corroded from sitting and not moving.
I am thinking maybe 500 miles on the belt (2011 season), the last belt that went did not wear this way and it took out my speedometer cable so guessing on mileage. I only rode it for a few miles last time (2012) when I noticed it eating the belt.
Everything appears to be OK, so I am just going to flip the belt and do a test run and see if it still wearing this way. Just looking for ideas on what else to check so I can start riding again, we are finally getting a base here, and thinking about going north again.
The first picture shows the side of the belt has a slice in it, and the third picture you can see a line running down the same side which is the sliding secondary side.
