tk44189
I have a 2003 viper with 1000 miles on it. I have been burning almost a quart of oil every 35-40 miles. Obviously this is not correct. I have adjusted cable and it is set to 20mm. The manual calls for 22mm +-1mm. Im thinking that the smaller the distance the less oil would be used. Now I have noticed that after riding the oil cable pulls out of the adjuster barrel. I think that might be were my problem is. Does anyone know if this is common and if there a fix. Any suggestions would be appreciated.
Thank You
Thank You
