YAMMIEGOD3:16
FRIEND OF MINE GAVE ME A SET OF SILVER ONES OFF A 2001 SXr 700 THAT WERE REAL NICE. I PUT THEM ON MY 2000 SRX fOR A CHANGE, REALLY LOOKS GOOD. 3:16 (yammie tony)
How's it handling.........did you long travel front??
YAMMIEGOD3:16
NO NO THIS SLED IS SLAMMED FOR ICE / GRASS RACING. 3:16 (yammie tony)
Devilin AblueDress!
Theres ben a few threads debating how handling would be differant with the slight differance in angles of spindle tubes. Any noticeable changes?
Any weight reduction ?
YAMMIEGOD3:16
NO PROBLEMS AT ALL AND THEY FIT LIKE A GLOVE. BOLT ON. ANDY NO. LOOKS ONLY!! 3:16 (yammie tony)
No offense to anyone I'm kind of chuckling to myself with all the questions.The trailing arms are identical to the srx .There the exact same as the 2001-2002 srx.
I like the silver arms compared to the blue Tony.
Devilin AblueDress!
pro116 said:No offense to anyone I'm kind of chuckling to myself with all the questions.The trailing arms are identical to the srx so are the spindles.There the exact same as the 2001-2002 srx.
No offense to anyone but go ahead and keep chuckling to yourself as they are in fact slightly different. SxR (factory longer travel sled) has a R stamped in them. SRX (factory shorter travel sled) have a V stamped in them. The differance in the 2 is the angle of the spindle tubes.
YAMMIEGOD3:16
ALL I CAN SAY IS THIS. I CAN,T POST PICTURES BECAUSE I DON,T KNOW HOW. THEY BOLTED ON LIKE A GLOVE AND ARE THE SAME PART # EXCEPT FOR THE 8DF-8CR MODEL CODE #. ONLY REASON I DID THIS WAS FOR LOOKS. 3:16 (yammie tony)
Arms
I have run one of each on the same sled with no difference in handling. There is no way anyone could tell the difference from the r stamped to the v stamped trailing arm when it is installed. Tony I am sure the silver looks better. Breaks it up a little. How was the Whiteout.
YAMMIEGOD3:16
DAVE, NO WHITEOUT, WENT TO A SNO-DRAG ON SUNDAY. COULD NOT DO BOTH. ANYWAY I LOVE THE SILVER ON THE 2000 BECAUSE OF THE LARGE '' SRX '' DECAL. AS FARR AS HANDLING, I DON,T KNOW HOW MUCH HANDLING COMES INTO PLAY 500 F.T. AT A TIME. 3:16 (yammie tony)
