can anyone tell me the proper operating temp of a sxr should be running at? the idiot light keeps coming on and ive been through it twice now i finally put in an aftermarket gage so i can monitor it but i have no idea what it should be running at? thanks
thefindian
Are you sure you dont have a air bubble in the system?
positive new water pump new belt burped it out of the bleader on the back pipe conecting the 2 heat exchangers while the back was in the air
roudyroy1
anything below 100c i think. thats when the light is supposed to come on
don't raise the back end up to high when bleeding..are exchangers all warm ????kristina said:positive new water pump new belt burped it out of the bleader on the back pipe conecting the 2 heat exchangers while the back was in the air
exchangers are warm 212 f seems really warm to me and it dont get that hot on the aftermarket gage when the light comes on maybe i got a janky light? so as long as its under 212 im good??...
the track was about 6 inches from the ground
I also have a temp guage on my 2002 SRX....the cooling systems are slightly different but the operating temps should be similar.
Once my sled is warmed up and being riden the guage indicates 130' - 140'F.
The Yamaha temp lights usually come on when temps are above 190'F[approx]
I would be concerned if your temp guage is indicating above 170'F under normal riding conditions.
JM.02c
JM.02c
jasburrito
Sounds like air bubble. Try jacking up the front. start sled. add fluid. sqeeze hose,lift hose higher than any other part of cooling system.repeat.
thefindian
When I fill one of these sleds with antifreeze I measure from the floor up to the fill cap with a level and a tape measure and set the back of the sled up so the bleeder in the back is 1 inch below the fill cap then I take out BOTH bleeders the one on the engine head and the one in the back I put a rag around the one on the head and I fill it up really slow just trickle it in when it starts to come out the bleeder on the head with no air bubbles in it install the bolt then go back to filling it, remember really slow and when it starts to come out the bleeder in the back let it run out good with no air bubbles then install bolt, then make sure you got antifreeze in the plastic res. up to the fill line and run it, keep an eye on the res. the first ride it will go down a little bit.
SRX500kid
That's odd some times ie even wonder if my idiot lights even work. I the 3 years I have had the sled both have never came on. Is that common or am I the idiot? :P not even the low oil light so I have no clue if they even work
thefindian
I have owned at least 10 Yamaha sleds in my life and I have only had the temp light come on one time and that was on the 4th of july with my old 89 exciter, we were drunk.....lol
