02 sxr600
JohnnieS
Ontario
Trying to test the stator resistance. Two plugs out of stator housing 1- 3 pin 3 white wires and 1-2 pin with 1 white/green and 1 white/ red. Any help on resistance values? Thx
i have the readings in my book, but i have it at my freinds shop, i can post readings later today.
I forgot I had the manual in my truck, here u go Pulser coil White/green-white/red 210 ohms and then measure between all 3 white wire,u will have 3 tests white to white white to white, white to white reading should be .36-.80 ohms good luck :2strokes:
