Bleeding coolant on SRX
hman
Saline Michigan
When I bleed the system I can get the air out the back of the sled when removing the bleed screw then a steady stream of coolant but then after I tighten that one and try to bleed up at the carb heater I get nothing,the radiator cap is off,rear end is lifted but no antifreeze.Anybody else have this problem.The last time I had the top end off and put it back together then bled it I got coolant to come out but it took awhile,then just barely trickeled out.
try mr.sleds trick. put front end up in air bout 1'-1.5' and let it burp out the rad cap while runnin. this is posted in here somwhere as well.
