max lug height
vmax4pjg
upstate NY
i looked around the site couldnt find nothing. what is the max lug hight i can run on my 2000 sxr 600, i probably will run studs too.thanks guys
1.5" will rub the front heat exchanger a little I had a kimpex aggresser on a 97 sx it measured something like 1.33 and that never rubbed.
If running studs, unless you go with 8t drivers, you won't be able to run really any taller than a 1" track. That is at least how it is on my pro action venture, which I doubt is any different than your sxr.
.92 track with studs works great for the trails, which is what I run.
X2 pretty much. Even running 1 1/4 with studds your rolling the dice running an effective stud height. IMO 8t drivers is a whole nother can of worms. Dropping to 8t is effectively way lower gearing. Will need to change gearing as well as it throws your speedo out of whack.
