vipersrxhouse
bought a 2003 viper for the wife
did the once over on the sled didnt find anything out of order
the sled is very clean and runs pretty good
there are 2700 miles on the sled
the issue i have i took the sled for a 100 mile ride and the follow day i checked it over and found fuel mixed in with the oil resivor. before we burn down the motor i would like to know what caused this so it can be repaired
your thoughts ?
your thoughts ?
95rxl650
This should resolve your issue. There's a few options.
http://www.totallyamaha.net/forums/showthread.php?t=88520&highlight=gas+oil+tank
vipersrxhouse
ok ill look at the check valves on the oil lines
the sled was in bins when i bought it so they may not even be there ! thanks
Devilin AblueDress!
vipersrxhouse said:ok ill look at the check valves on the oil lines
Make sure your gas tank is venting as it should as well. When fuel warms up it expands, when fuel is shaken it expands. Pinched/blocked/plugged vent lines will force expanding fuel down the path of least resistance.
