viper motor mount question
lsbufis
Canada
Alright so my viper has been chewing the top part of my belts and i'm getting sick of this things already.
Is there supposed to be abit of flex when lifting the motor by the primary clutch??
I've tried tightening all my mounts and still having abit of flex...
Need help
on the front side of the motor mounts there is 2 bolts well now 1 of them is broken/stripped.
What size bolt is that?
But now i overtightened one of the 2bolts on the front lower mounts near the exhaust.. and i was able to take it out by hand.... Will it be fine with 1 bolt?
1 is in there good and i'm not touching it lol. the other 2 on the mag side are good to go
Brought it to a local dealer, and she;s all fixed up and aligned now. can't wait to try it out
You can also replace the left front motor mount with one from an srx. they have 3 bolts going into the case instead of two and this helps to prevent broken bolts.
Next season i'll be getting a torque limiter installed for sure!! is the SRX one better than the VIPER one? or same thing
the factory srx dog bone link is what you need to install, it was also sold over the counter as a upgrade for the viper from dealers. With all the guys who part out sleds, it shouldnt be too hard to get one. This will eliminate 100% of the motor mount issues .
