jimmy dodge
I was riding last weekend and I was having an intermitent problem reving over 6500 rpm (this was happening more often than not)
During the summer I changed both clutches, added an XT skid and a 1.25" track. That's about all but I've also neglected the carbs over the past couple seasons. So I've pulled them off, took them apart, cleaned them and I thought I'd throw in a new set of reeds there's nearly 23,000kms on the motor (complete rebuild aprox 7,000kms ago)
What I have found is that there are plastic inserts in the throat of the reed cages and both are loose. There's close to 1/8" of play, is this normal?
I'm also putting my primary clutch back on
Jim
Jim
chris700readhead
The stuffer does not fit in there snug it just sits there till the boot is bolted on.
jimmy dodge
chris700readhead said:The stuffer does not fit in there snug it just sits there till the boot is bolted on.
Ok, thanks, I'll bolt it back together
