fuel pump relay
I have a 2006 Attak and recently had what I believe is a common problem - failed fuel pump relay switch.
The fuel pump does not come on when the key is turned. In a pinch I had to warm the replay switch and give it a couple of taps to get it functional again. Permanent solution is to replace the relay switch.
Old part number is 8FP-81950-01-00. The upgrade part number is 8GN-81950-00 (red in color).
Since the upgade , I've not experienced this issue again.
The original part number was 8FP-81950-00. I had changed it to 8FP-81950-01-00 simply because the dealership informed this would solve my problem. Problem did not go away, so I just upgraded to the the red one. Since doing this I had no further failures.. If the part is the same (and I believe it is), then yes it would be the same. Seems this is a common part used over the years...
