help me 02 viper trouble
99srxracer
new hampshire
I got an 02 viper with 3000 miles I'm thinking my stator f-in up. Bogs at 70 lights dim cut out my gauge cluster flashes out like it resetting itself. I'm thinking my stator is during? Anybody got any ideas thanks
You may want to check your wiring harness. I've read a lot of people with similar problems with their sleds and it turns out to be a bare wire somewhere. Sounds like under the engine and under the airbox by the steering stem are the major problem areas. You want to make sure before you throw parts at things. I've learned that the hard way from working on cars. Its all a learning process.
it sounds more like a harness rub, over time you might need to fix both.
check under motor where it goes over the sway bar housing,
under the cdi box,
where it plugs into the stator,
under the handle bars, though this one doesn't bother much on a viper as they routed the bars differently
and where it turns under your front bumper brace
Good news guys went and picked up a stator first thing. Came home pulled airbox checked harness looked good pulled it apart swapped stator and back on her in no time running great thanks for the help
